22j140
#1 Posted : Monday, May 3, 2010 12:16:18 PM(UTC)
22j140
I need to know what part I need to repair this model dryer. The dryer will heat up for a few minutes and then stop heat and will not dry the clothes. I need to know if it is the element ofr something else.
Thanks,
Kris Allen
#2 Posted : Monday, May 3, 2010 4:27:53 PM(UTC)
Kris,
The first thing I would do is make sure the dryer vent line is clean all the way through its outlet. Remove the rear panel. Remove the lint chute (#1 on the diagram) and clean it inside.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER4624BQ1 | AppliancePartsPros.com
