The heating element is activated and emits a low heat when Air Only is selected from the menu option. In addition, High heat was measured at 155 degrees, Med heat 140 degrees, low heat 132 degrees and extra low heat 128-130 degrees, and air only at 128 degrees. I have replaced the heating element, the thermistor, the thermal cut-off, the thermostat, thermal fuse, and the machine control electronics board. I did all this within the last 2 weeks since the initial problem was the heating element was burned out (broken element). Do you have any idea what the issue is and what actions I need to take to correct the problem?:confused:
problem maybe themistor to the right of thermal fuse on blower housing .i usually carry that part when i hear about that problem . part#ap3919451
I replaced the thermistor and that did not fix the problem
check wiring harness at control board under top of dryer .are there any error codes
The issue was that the heating element was grounding out against the metal heat box. Lesson learned check and make sure heating element is secure on white installation fittings.
