2 Pages12>
ctjch11
#1 Posted : Friday, April 30, 2010 6:56:52 PM(UTC)
ctjch11
First off let me thank you for letting me post here, I have a whirlpool side by side, I am having trouble locating the defrost timer I have looked inside
the control panel, I have looked inside the toe kick, also in back all around the compressor, Inside the freezer behind the panel?? I am confused, could someone please shed some light. Thanks in advance:confused:
#2 Posted : Saturday, May 1, 2010 2:01:31 AM(UTC)
Replacement parts for WHIRLPOOL ED5JHGXRB00 Refrigerator | AppliancePartsPros.com
Take a look at Item 6 in Section 11
ctjch11
#3 Posted : Saturday, May 1, 2010 3:38:08 PM(UTC)
ctjch11
Hey Denman , thanks for your help, But i replaced that circuit board before posting here. That is part # 4388932, The Defrost timer is part
# 2188175 The circuit board i was told by a appliance parts house was
possibly the problem, If not it was either the Defrost Timer or the Heater
element. I want to replace the Defrost Timer now. But i need to find the location. I thawed out the coiles last night to bide me some time. The refridgerators temp dropped to 38 degrees, for now. Could you please help with locating the Timer, Thanks again
#4 Posted : Sunday, May 2, 2010 10:49:50 AM(UTC)
[COLOR="Blue"]Hey Denman , thanks for your help, But i replaced that circuit board before posting here. That is part # 4388932, The Defrost timer is part
# 2188175[/COLOR]
Sorry but I do not understand.
4388932 (AP3109394) is the timer
2188175 (AP329888175) is the heater element
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202255377.pdf
As you can see there is onlt one board in the unit and that is the Adaptive Defrost Board which does the same thing as an old style electric timer.
I did note that although the wiring diagram shows a bi-metal (defrost thermostat) I could not find it in the parts breakdown.
If you do not have a meter to check the components I would replace both the heater and the bi-metal.
ctjch11
#5 Posted : Sunday, May 2, 2010 11:41:28 AM(UTC)
ctjch11
Denman thanks again for your help, i have a question. If i unplug the fridge and cut the 2 wires on the defrost thermostat , put them together
plug the fridge back in and see if the defrost heater starts to work, If it
does replace the defrost thermostat. If not Replace the Defrost heating
element ?? Please give me your input. Thanks again
#6 Posted : Monday, May 3, 2010 3:13:09 AM(UTC)
[COLOR="Blue"]If i unplug the fridge and cut the 2 wires on the defrost thermostat , put them togetherplug the fridge back in and see if the defrost heater starts to work, If it
does replace the defrost thermostat.[/COLOR]
Yes, as long as you can force it into a defrost cycle. Often you will notice that the defrost thermostat is bulged out, water has gotten into it and frozen. If this is the case it needs replacing
[COLOR="Blue"]
If not Replace the Defrost heating element ??[/COLOR]
Yes
ctjch11
#7 Posted : Monday, May 3, 2010 11:00:46 AM(UTC)
ctjch11
Thanks Denman i am going to check the thermostat with an ohm meter
It has not bulged out , But it did have ice almost completely covering
the thermostat before i defrosted the coiles manually. A 4 year old fridge should not have any problems. Thanks again i will post back with the outcome.
vsopvince
#8 Posted : Wednesday, May 5, 2010 5:23:04 AM(UTC)
vsopvince
I have a whirlpool side x side also. Open the refrigerator side and look at the section where you set your temperatures. What you're looking for should be located inside that panel. A lot fo those models actually came with an adaptive defrost control(approx. $40 for that part).
MFrench
#9 Posted : Wednesday, May 5, 2010 12:14:00 PM(UTC)
MFrench
I feel like I'm in the same boat, sort-of. I read the cool freezer/hot refrigerator post but I don't think I have a physical defrost timer. My damper is working FYI, My coils are pretty frozen up. Is there a way to test the digital versions (no physical timer that I can tell). Whirlpool gold gc5shexnq00. If not, which controler board do I need?
Thanks in advance.
#10 Posted : Thursday, May 6, 2010 2:43:32 AM(UTC)
Guest (5)
2 Pages12>
