bleedcubblue
#1 Posted : Tuesday, April 27, 2010 7:52:13 AM(UTC)
bleedcubblue
Hello, having a problem with an old Frigidaire dryer. It seems to heat up inside the drum (and the top of the cabinet gets warm), but blows almost cool air out the vent. I have disassembled the unit. The heater coils test 12 ohms, and I tested what I believe are the two thermostats, both read .4 ohms on the meters lowest setting. No obvious lint obstruction. Any idea what ails this machine?
sidfink43
#2 Posted : Friday, April 30, 2010 6:10:57 AM(UTC)
sidfink43
I have not worked on that old a model but it sounds like there is an obstruction somewhere. Take off the blower housing and check the fan and take off the internal exhaust and check it.
