I just received the replacement auger I had ordered on Friday from Appliance Parts Pros. Now I have the ice-maker (pictured above) out of the freezer and need to remove the part labeled 320 in the picture near the bottom of the picture. I can't determine if this piece is threaded on or somehow secured in some other way. I don't want to force it off and break anything. Has anyone replaced this before? Do I just force it with a pair of pliers?
It is secured by the cir clip part 321 on the diagram. It's in a groove on the shaft and can be removed prying off with a small flat head screwdriver using the slit you can see in the clip.
I have the same ice maker with a broken augur; I'm trying to figure out how to remove part 325 from 352. It looks like there are two tabs on 325 that would release it, but they don't seem to move and I don't want to force them ... I've broken too many things that way. Any thoughts?
Originally Posted by: woodchuckie  It is secured by the cir clip part 321 on the diagram. It's in a groove on the shaft and can be removed prying off with a small flat head screwdriver using the slit you can see in the clip. I'm trying to remove part 325 from 352 -- any suggestions?
