Hi I have a probem with my front loader that i need help with. My wife over loaded it and the drive belt snapped - no problem i thought but after i fitted the belt i noticed that the inside barrel is really loose and if you manually rotate the barrell it is loose like its detached from the main drive - although it will rotate manually but it scrapes the exterior drum
can anyone help me please
Drum Is Broke. I Had Frigidaire Do The Same. Warrenty Was 25 Years For This But No Labor.
