wzard841
#1 Posted : Wednesday, April 28, 2010 12:29:53 PM(UTC)
wzard841
On finding the evap frosted and the blower not running I tested the blower by spinning it while still plugged in but turned off. Blower ran but stopped after the unit was turned back on and cooled off.
I replaced the blower with a new one as I didn't want to lose the food in the fridge side.( freezer mt) Investigating the cause of failure I removed the back bearing assy and the rotor (watch the tiny thrust washers) & discovered a small qty of water in the motor. I dried it out and reinstalled it.
If I had known to do this first it would have saved me the cost of a new blower. Hope this helps someone.
#2 Posted : Wednesday, April 28, 2010 5:29:28 PM(UTC)
Thank you for sharing your repair with us. Your post was very informative.
Good luck with your refrigerator.
#3 Posted : Thursday, April 29, 2010 2:46:04 AM(UTC)
The source of the water could be the icemaker. I would empty the icemaker, put 115 volts to the water solenoid for the icemaker for about 9 seconds and see if the icemaker overflows or the filler tube leaks.
wzard841
#4 Posted : Thursday, April 29, 2010 3:52:50 AM(UTC)
wzard841
The ice maker has never been used.
Whirpool oven blower repair (Oven Repair (including Ranges and Cooktops))
by Gatorsarous 12/17/2012 6:30:32 AM(UTC)
