Fan works - I can not get low and high switch to work. What do I need to do and what part do I need.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Hi Joe, Most likely the problem caused by a bad control board. Unfortunately this part is no longer available. There is a company which can help you to rebuild the old control board. Here are the break down diagrams for the Whirlpool microwave Model MH6600XX0Gene.
