pamilyas@gmail.com
#1 Posted : Saturday, April 12, 2008 10:00:49 AM(UTC)
pamilyas@gmail.com
My washing machine will not spin or drain. After the rinse cycle is complete there is a clicking noise and that is all, no noise or movement, it just stops. What could be the problem? I tried looking at different forums and have seen several solutions. Is this something that I could fix or do I need to call a repairman? I have some experience working on washers, but I am unable to diagnose.
bambiblaster
#2 Posted : Saturday, April 12, 2008 5:26:07 PM(UTC)
bambiblaster
Rank:: Advanced Member
Check the lid switch may be bad
jasarite
#3 Posted : Friday, April 25, 2008 1:34:17 PM(UTC)
jasarite
My washer(whirlpool) would drain but not spin while loaded.I tried it empty with just water and it would spin. The washer has a clutch assembly between the transmision and tub that was worn.I replaced the clutch and it now spins when loaded. Wish I could have found this answer when I was asking...
jasarite
#4 Posted : Saturday, April 26, 2008 8:48:21 AM(UTC)
Your clutch may have worn out due to dragging brake shoes, does it jerk stop at the end of spin?
sailman
#5 Posted : Saturday, May 3, 2008 8:03:10 AM(UTC)
sailman
thanks so much. tried your test and got same result so now I know what to fix. Was you spin not working in all modes , Reg wash, gentle, etc ? Spin works with clothes in Gentle for me but not regular or perm press ?
ernest scales
#6 Posted : Tuesday, May 6, 2008 1:21:16 AM(UTC)
ernest scales
my washer want do any thing when i turn it on the time comes on then it read fi
#7 Posted : Tuesday, May 6, 2008 3:23:12 AM(UTC)
Need make and model#
johnerone
#8 Posted : Tuesday, May 6, 2008 8:41:01 AM(UTC)
johnerone
whirlpool, Model lsn1000pq0
johnerone
#9 Posted : Tuesday, May 6, 2008 8:44:46 AM(UTC)
johnerone
i have changed the switch but problem persist
BiggMoe
#10 Posted : Saturday, May 17, 2008 9:54:17 AM(UTC)
BiggMoe
That seems to be my problem too,
Where can I get a Diagram and the part I need:eek:
Model LSR5132PQ1
