mrfixit1959@yahoo.com
#1 Posted : Monday, April 26, 2010 3:45:49 PM(UTC)
I have a Frigidaire fridge that the freezer part is plenty cold and even has frost on back panel, but the fridge isn't cooling. I can't seam to find any diagrams that show where parts are. Schematits yes, but how do I find where the defrost timer even is located to adjust it? Would unplugging fridge to let it defrost help or is that only a temperary fix?
#2 Posted : Tuesday, April 27, 2010 3:19:40 AM(UTC)
Replacement parts for FRIGIDAIRE FRT18KB2CW2 Frigidaire/refrigerator | AppliancePartsPros.com
Defrost Timer is 23 (F23) in Section 3.
There is usually a hole in the cover to let you rotate the timer's cam.
Yes, if it is a defrost problem as it will just ice up again.
First I would check to be sure that the freezer fan is running. It is required to push cold air down into the fresh food section.
Next, remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item in Section ) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item in Section ) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item in Section ) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
