Brownibe
#1 Posted : Sunday, April 25, 2010 3:46:01 PM(UTC)
Brownibe
I have a Maytag dryer - model PYE2200AYW. When I press the knob to start the machine, it won't start. I studied the diagram posted on this website. Is the controller/timer the correct part? Do I need to purchase the resister as well? Please advise.
Thank you. beth
magician59
#2 Posted : Monday, April 26, 2010 7:22:47 AM(UTC)
magician59
A good place to star checking is the outlet. You should have 240VAC at the outlet (It won't be a perfect 240 volts, but should be reasonably close). If you don't have it, check to make sure the breaker isn't tripped. If you have the correct voltage, tell us whether you hear any noises when you try to start the dryer.
#3 Posted : Tuesday, April 27, 2010 2:15:57 AM(UTC)
Probably not the timer.
The below only applies if there is no noise (hum) when you try to start the unit.
More likely the thermal fuse, Item 5 in Section 4 or the door switch.
Unplug he unit and check the door switch with a meter should go to 0 ohms when the door is closed.
Unplug the unit and check the thermal fuse with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
