hawnfridge
#1 Posted : Saturday, April 24, 2010 12:41:57 PM(UTC)
hawnfridge
Aloha from Hawaii,
I bought a house with an existing Refrigerator from Kitchen Aid model ksrs27ihss02. We noticed defrosting a couple of days ago but it seemed like it was just the freezer door not closing properly. After clearing items to assure the door closed tightly we noticed the freezer was continuing to defrost as we had water leakage out of the water dispenser. I pulled the ice bucket out and noticed there was frozen water inside the ice drop down area that was slowly melting and appeared to be the reason for the leakage. I pulled that ice out and shot off the ice maker. From that point both sides Refrig AND Freezer defrosted quickly and are now both warm. It seems like the fans are both working. I did go under and vacuum clean the coils but an hour later neither side seems be any cooler. My uncle suggested that the defrost auto switch may be sticky and may have to be moved to OFF. I have also been reading about dispenser issues. Does anyone have suggestions for a trouble shooting methodology I could use to eliminate issues? Unfortunately the extended warranty that the previous owner of the home had expired last year without my knowledge. I just dug through his paperwork that I found so I want to try fix this myself if it is easy enough. I don't have a huge amount of experience working on stuff like this so if you think this is going to be a more then novice level fix I will hire someone.
Mahalo:confused:
hawnfridge
#2 Posted : Sunday, April 25, 2010 9:51:34 AM(UTC)
hawnfridge
Follow up on my issue. I spoke with a local refrigeration person who told me to take the back panel off the Kitchen Aid and feel the compressor for temperature. It was extremely hot so he suggested I let it sit and cool off because perhaps it had kicked off and just need to re-set when it cooled down. I did this and set it back up and nothing. No cold air inside at all. Seems like it is trying but not working. Also, the compressor was very hot again. The fans were working. About 5 minutes after I removed the back panel the fan went off. I unplugged and replugged and the fan came back on. It is now sitting unplugged so I don't overheat. I don't feel any warm air blowing out the back.
Sounds like I need someone in to look at it. How much should I spend on a Refrige like this before it makes better sense to get a new one. Are they only supposed to last 10 years? BTW, my warranty service says that within 10 years they will pay for a new compressor, condensor as long as the refrig was used correctly. Is that worth pursuing? Mahalo again.
FridgeDoctor
#3 Posted : Sunday, April 25, 2010 1:36:49 PM(UTC)
FridgeDoctor
Groups: Expert
If what you have written is accurate, you mentioned that the fan by the compressor ran, then stopped, and when you unplugged and replugged in, the fan then started, coupled with the "No cold air inside at all" I would have to believe the problem is centered around your compressor failing to start, since on some model kitchenaids, the condenser fan gets power from the compressor, and so runs when the compressor tries to start, and stops when compressor cycles off. Due to the complex nature of this type of refrigerator repair, and the dangers to both your health and your property, I would recommend you have this at least inspected by a professional.
hawnfridge
#4 Posted : Sunday, April 25, 2010 10:48:08 PM(UTC)
hawnfridge
Aloha FridgeDoctor,
I bought a new Kenmore Elite (the French one) today. It seemed to be the prudent thing as I read up on the reviews of Kitchen Aid and none were really that good. Better money spent on a new investment and the energy efficiency seemed like it would pay for itself in a few years. What do you think about Sears extended warranty on this item?
FridgeDoctor
#5 Posted : Monday, April 26, 2010 5:54:42 AM(UTC)
FridgeDoctor
Groups: Expert
Im sorry you felt the need to go purchase a new refrigerator without at least having your original inspected, you could have saved yourself a lot of money. But, since 70% of Kenmore refrigerators are made by Whirlpool/Kitchenaid, you likely purchased another Kitchenaid, but believe it or not they are still one of the better products out there. I hate to burst your bubble, but all the money you "save" with this energystar refrigerator, will not come close to paying for the refrigerator if you owned it for 20 years.
Lastly, depending on what the extended warranty covers, such as sealed system repairs, i.e. a new compressor, would factor into MY decision to purchase it. If the ext warranty only covers minor repairs, excluding the sealed system, the cost of the warranty will likely be MORE than what a minor repair would cost on average.
Refrigerator on but warm in refrig and freezer (Refrigerator & Freezer Repair)
by traceymcc3 3/23/2014 2:44:44 AM(UTC)
Refrig and Freezer not Cooling (Refrigerator & Freezer Repair)
by RBazela 11/20/2011 8:17:35 AM(UTC)
GE Artica Top Freezer Refrigerator: refrig and freezer not cold (Refrigerator & Freezer Repair)
by bigman812 11/12/2011 10:57:31 AM(UTC)
refrig and freezer not cooling (Refrigerator & Freezer Repair)
by gwaldron 6/14/2011 12:01:25 PM(UTC)
Refrig and freezer not cold enough (Refrigerator & Freezer Repair)
by TRMORR 2/1/2010 5:42:37 AM(UTC)
Refrig and freezer not cooling (Refrigerator & Freezer Repair)
by donerite44 10/9/2009 12:08:16 PM(UTC)
Refrig and freezer stopped working, then started...then stopped again (Refrigerator & Freezer Repair)
by Auvan0876 8/28/2009 1:11:30 PM(UTC)
refrig and freezer are too cold (Refrigerator & Freezer Repair)
by mobrien1 3/16/2009 6:24:23 AM(UTC)
Refrig and freezer both warm, clicking noise (Refrigerator & Freezer Repair)
by rono 12/19/2008 11:06:16 PM(UTC)
