crlowder
#1 Posted : Saturday, May 3, 2008 12:47:44 PM(UTC)
crlowder
The element is good because it works in the other position. I replaced the switch and that was not the problem.The light comes on but the element does not heat.
misterfixall
#2 Posted : Saturday, May 3, 2008 3:11:11 PM(UTC)
misterfixall
Did You Replace Block That Burner Goes In To
crlowder
#3 Posted : Sunday, May 4, 2008 6:09:05 AM(UTC)
crlowder
Will try that. Thanks.
crlowder
#4 Posted : Friday, May 16, 2008 9:23:45 AM(UTC)
crlowder
I replaced the block but that didn't fix it . then I replaced thr T-stat,S-unit
Part # AP2928086. That solved my problem.
