So my SS would stop cooling and the food in the freezer would thaw and the fridge would get into the 50's.
I replaced the computer board near the temp. dials because I was told it controls the defrost and the defrost was probably the problem. About two days go by and it works fine then the freezer gets warm and everything defrosts.
To get it cold again I crank the temp. controls to max and hear the motor kick in little while latter the motors off and fridge is still 50's. I open shut the freezer door a few times until I hear the motor come on again and let it sit. By the next morning its all cold like its supposed to be.
What's wrong with this dang thing????
Bump........ Anyone got an idea????
