Diagnose noise on Maytag LSE7800 dryer (stack) at start up. Squeals then dies out as dryer spins up. Is this symptom that drum roller(s) needs replacement??
If it's a high pitched squeel, it's likely to be: A slipping belt; the idler pulley; or the blower wheel starting to slip on the motor shaft.
