I am trying to troubleshoot a Whirlpool Duet GHW9100LW that has very wet clothes when the cycle is done. The size of load doesn't matter. I have cleaned the course filter on the drain pump. I did notice when I did this and went to "Drain/Spin" the speed would initially accelerate and then slow spin and then rock and then slow spin and repeat the rocking. I ran a Diagnostic Test and everything seemed to be OK (it spun at high speed). I am looking for a suggestion on what to do next. Thanks in advance
I would recommend to check all wires connection, especial ground and neutral. Otherwise it sounds pretty weird.
You might have a bad pump. Remove all the water and clothes and check spin. If it now spins, that confirms a bad pump.
mine is doing the same thing! it starts to spin and then stops circles a couple times and the tries again, we've replaced the pum[ once already, we're going to try the drive belt and see if that works.
