Tweetsman
#1 Posted : Tuesday, April 29, 2008 10:23:16 PM(UTC)
Tweetsman
Someone left the freezer door open just a little. The light switch froze. Once thawed it flops with no snap to it and doesn't turn on the light. The light bulb is good. How do I change/check the switch? Is there a diagram somewhere to look at?
Thanks for the help.
#2 Posted : Wednesday, April 30, 2008 5:07:55 PM(UTC)
The first thing I would do is carefully try to defrost the light switch, using a hair dryer.
Tweetsman
#3 Posted : Thursday, May 1, 2008 8:14:42 PM(UTC)
Tweetsman
Thanks for the quick reply Gene. The switch is no longer frozen so I need to remove it. I've thought of simply trying to pry it out with a screw driver but I don't want to break any plastic. Any other thoughts?
#4 Posted : Friday, May 2, 2008 1:41:52 PM(UTC)
The only way to remove the light switch is to carefully slide a small flat-blade screwdriver under the switch and push the locking tab, then pull out the switch. Order the new switch fist and you will see where the locking tab is.
- The part number for the light switch is AP3854028
