dave11223344
#1 Posted : Thursday, May 1, 2008 5:57:58 PM(UTC)
dave11223344
Hello this dishwasher is not cleaning the water is hot the level is ok the top arm is not moving when I open the door I ran with door open no water pressure to top arm and very little to bottom arm I think wash pump has little pressure I took bottom arm off it was clean under there all holes are clean.
#2 Posted : Friday, May 2, 2008 1:25:11 PM(UTC)
Remove the pump cover and check the impeller.
Kenmore Dishwasher Not Cleaning (Dishwasher Repair)
by jmin 2/12/2009 5:18:33 AM(UTC)
