psmccoy
#1 Posted : Monday, April 19, 2010 10:31:39 AM(UTC)
psmccoy
How do I replace the rear drum seal? It is a felt strip about 1.5in. wide.
#2 Posted : Tuesday, April 20, 2010 2:56:00 AM(UTC)
Order the felt here AP4038955 You will need to use a sharp knife to pull the old one off and remove old cement. You will need to also buy high temperature rubber cement to put it on.
rear drum seal (Microwave Repair)
by Steve Rado 11/14/2013 4:42:02 PM(UTC)
rear drum seal replacement (Dryer Repair)
by mfd611 7/5/2009 10:42:37 AM(UTC)
Need Help Replacing Rear Drum Seal (Dryer Repair)
by oconnors 11/8/2008 7:25:09 AM(UTC)
