chavez107
#1 Posted : Saturday, April 17, 2010 8:43:26 AM(UTC)
chavez107
Dryer blowing thermal fuse. Have cleaned out dryer for lint and also cleaned out exhaust duct from house and blew out big ball of lint and the dryer worked fine for several loads (10-15) and then just blew the again. what else can be making it blow the fuse?
sidfink43
#2 Posted : Monday, April 19, 2010 9:01:50 AM(UTC)
sidfink43
If you have cleaned out all of the air passage ways inside the dryer and in front and of and past the fan then the fan itself may be bad.
#3 Posted : Tuesday, April 20, 2010 1:10:24 AM(UTC)
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
