rizzi
#1 Posted : Sunday, April 18, 2010 2:49:23 PM(UTC)
rizzi
hello all, i took out the ice storage bin to unclog it(ice wouldn't dispense due to mass of ice in bottom). lifted the control arm to stop icemaker, took out the bin, unclogged it, re-installed it, flipped the arm down, and no ice 48 hrs. later. what did i miss or do wrong? thanks.
rtipaldi
#2 Posted : Monday, April 19, 2010 8:09:53 AM(UTC)
rtipaldi
You probably have a faulty water inlet valve located at the bottom rear of the refridge. After you reassemble ice maker check for water fill up in the freezer tray. Replacing the valve is easy.
