the drain pump does not always work - leaving the machine full of dirty water. Pump seems ok when supplied by separate electrical feed. Problem with wiring or switches in control logic I think, but don't have circuit diagram or function sequence to work it out. maybe just the pump sticking ?? Any suggestions please. Much appreciated.
Looks like this is not American model and we are not able to find any information in such case. Guessing is not a good way.
