mshaw1679
#1 Posted : Wednesday, April 14, 2010 4:26:06 PM(UTC)
mshaw1679
Hi I have an AMANA NAV5805AWW washer that has stopped spinning more and more with each cycle, the clothes are still very wet and an additional spin cycle dosent help much at all. My hubby took it apart and said the belt appeared loose but he couldn't tighten it...I'm in a panic :eek:
I have to have a washer!! Any help is welcome!
sidfink43
#2 Posted : Saturday, April 17, 2010 3:53:05 PM(UTC)
sidfink43
Ok, the belt does not tighten on these models. The likely cause of the problem is the thrust washer. This kit should fix you up and the instructions are included. Getting it back together is sometimes difficult but it can be done.
Part number: AP4009132
bigchief
#3 Posted : Tuesday, February 22, 2011 10:00:50 AM(UTC)
bigchief
Did you ever figure out what part needed to be replaced to fix this? My machine has the same issue now. Thanks.
