DBINMA
#1 Posted : Friday, April 16, 2010 10:30:15 AM(UTC)
DBINMA
The fill tube to my ice maker keeps getting blocked with ice. I melt it out with a hair dryer then it becomes blocked again. From what I've been reading it's probably a leaking water valve. What I'm trying to figure out is which valve should I replace. Looks like on my model there are 3. One near the ice maker and 2 at the back of the frig. Any help is appreciated. Thanks
magician59
#2 Posted : Friday, April 16, 2010 11:25:12 AM(UTC)
magician59
Never seen a third water valve near the icemaker. Any way you can post a photo?
DBINMA
#3 Posted : Friday, April 16, 2010 11:35:03 AM(UTC)
DBINMA
Here is a link to the ice maker. The valve is #9 Thanks
DBINMA attached the following image(s):
magician59
#4 Posted : Friday, April 16, 2010 12:37:13 PM(UTC)
magician59
That's pretty likely to be the culprit, since it's the last one in the series from water source to icemaker.
DBINMA
#5 Posted : Friday, April 16, 2010 12:41:55 PM(UTC)
DBINMA
I'll start by buying that one then. Thanks for helping out, definately appreciate it.
