tom bacci
#1 Posted : Friday, April 16, 2010 10:58:58 AM(UTC)
tom bacci
My freezer in blowing cold air but not enough to freeze anything...I cleaned out the coils underneath the which had allot of dust on them but that was several hours ago and the cooling hasn't gotten any better...any other ideas...the refridgerator is cooling fine...
magician59
#2 Posted : Friday, April 16, 2010 11:01:30 AM(UTC)
magician59
What's the actual temperature inside the freezer?
tom bacci
#3 Posted : Friday, April 16, 2010 11:07:49 AM(UTC)
tom bacci
35-40 degrees
magician59
#4 Posted : Friday, April 16, 2010 11:20:14 AM(UTC)
magician59
Remove the panel inside the freezer to expose the evaporator coil. While the machine is running in normal operation, the coil should be completely covered by a thin coat of frost. Also, the evaporator fan runs with the compressor and condensor fan. Report what you observe.
tom bacci
#5 Posted : Friday, April 16, 2010 11:23:53 AM(UTC)
tom bacci
I am at work now and I know you will be leaving for the weekend shortly if it is not covered by ice what does that mean and if it is coverd by ice was is my next step...
