Sean
#1 Posted : Wednesday, April 30, 2008 10:25:12 AM(UTC)
Sean
Dishwasher seems to run but will not fill with water. All water supply lines are turned on.
misterfixall
#2 Posted : Wednesday, April 30, 2008 12:51:44 PM(UTC)
misterfixall
you may have problem with fill valve, with meter check for 110 volts to valve,if no voltage ,check float switch asssembly for power ,or something like caked on detergent in float cup
