crs2007
#1 Posted : Wednesday, April 30, 2008 5:08:14 AM(UTC)
crs2007
Last week I was having a terrible squeaking noise in my GE gas dryer. I determined I needed to replace the glides and drum support. I did that and now no more noise.
However...
After putting it back together, it now overheats and shuts off a few mins after the burner kicks on. It didn't have this problem before I did the repair. Is there something I could have tripped or put back together wrong that would cause it to overheat??
Here's what I know it's NOT
- Not vent blockage. I've checked the vent where it exits the dryer and where it exits the house and there is no blockage.
- Not a door switch. It will run a full cycle on "no heat"
- Drum is turning
Any advice would be greatly appreciated.
**Sorry for the misspelling in the title. I was meant to say "shuts" off. If someone could change it that would be good
misterfixall
#2 Posted : Wednesday, April 30, 2008 1:02:10 PM(UTC)
misterfixall
so you feel lots of air blowing outside?
crs2007
#3 Posted : Thursday, May 1, 2008 4:29:45 AM(UTC)
crs2007
Yes, there is definitely a good airflow coming out of the vent. The weird part is that is was working perfectly before I replaced the glides. Makes me think I did something wrong when I put it back together.
