prconte
#1 Posted : Wednesday, April 30, 2008 3:53:13 AM(UTC)
prconte
It takes at least three cycles to dry one load of clothes in my Amana LEA80AW. What parts should I look into replacing?
#2 Posted : Wednesday, April 30, 2008 5:11:20 PM(UTC)
Most likely the problem is a clogged exhaust line or/and an air ducts inside the dryer.
Here are the break down diagrams for the Amana dryer Model LEA80AW
prconte
#3 Posted : Friday, May 2, 2008 11:21:09 AM(UTC)
prconte
What's the best way to get to the air duct?
#4 Posted : Friday, May 2, 2008 11:52:11 AM(UTC)
You have to remove the front panel (#14 on the front & top parts break down diagram).
prconte
#5 Posted : Friday, May 2, 2008 12:38:14 PM(UTC)
prconte
I checked air duct and exhaust line, no clog. What should I look for next? Is the exhaust air supposed to hot or cold? My dryer is blowing out cold air, but the element in the back of the dryer (viewing from inside the drum through the door). help!
Guest (4)
LG Gas dryer doesn't dry clothes in one cycle (Dryer Repair)
by anuison 12/1/2008 8:52:01 AM(UTC)
