hung380
#1 Posted : Tuesday, April 29, 2008 7:52:18 PM(UTC)
hung380
hello everyone,
Got my self a little problem with the dryer and need some advice.
My whirlpool dryer runs but the heat only stays on for about 5-10 minutes then no more heat (dryer still running). I have to turn my dial to off then on again (reset)for it to work again then same thing happens again and again. I have checked the ducts and everything seems clean and plenty of air flow. Im thinking it might be the gas valve coils or the thermostat.
Any suggestions? thanks
#2 Posted : Wednesday, April 30, 2008 2:15:49 AM(UTC)
If you have a plastic button on the front panel, pull it off and check your flame. If it seems "normal" with the flame bluish, you probably have bad gas valve coils.
