MrStarbucks
#1 Posted : Sunday, April 11, 2010 9:02:49 AM(UTC)
MrStarbucks
I have a Whirlpool washing machine (Top Load Agitator). 19 yrs old. There had been some light clattering during Wash & Rinse cycles. NO Clattering on Spin or Fill. At any rate, life came to a halt when the machine is pouring smoke from machine and the motor only gives a strong HUMMMMM (louder version of holding the mixer tines of a kitchen mixer when it's turned on).
I have the motor, gearbox, and pump out. My assumption is my motor is toast. Could there be any other variables such as gearbox locking up? The motor shaft turns free and easy going clockwise. has much noise, rough spots, and squeaking turing the shaft counter-clockwise. The gearbox seems to turn free n easy while out of the machine. There is some pivot play where the long shaft goes into the gearbox but I assumed that was design in nature (it's a circular play give or take of 10 degrees all the way around.
Any help would be appreciated as far as other variables before I start buying parts.....David (aka MrStarbucks)
sidfink43
#2 Posted : Wednesday, April 14, 2010 4:51:07 AM(UTC)
sidfink43
Hi David
Given the age of your machine and the possibility that you may be looking at both transmission and motor replacement I strongly suggest you bid the washer a fine farewell (maybe a small party with a nice latte and scone) and replace it with a basic top loader.
In our area you can get one on sale for less than $350.00. You have 19 years of good service from your old machine, which is great but all good things must come to an end.
