3 Pages123>
sueandrob
#1 Posted : Saturday, October 13, 2007 4:08:57 PM(UTC)
sueandrob
Our Bosch diswasher makes a terrible, loud, deep pitched, gutteral noise several times during its cycle. The first incident occurs two minutes after we start the cycle. The dishes still get clean, the tub drains, besides the noise, all seems well.
okbobcats
#2 Posted : Sunday, October 14, 2007 5:26:49 AM(UTC)
okbobcats
your drain pump is going bad.
#3 Posted : Sunday, October 14, 2007 8:44:14 PM(UTC)
Hi sueandrob
The first thing I would do is try to pin point the noise. I've seen many times when such noise was coming from the water shut off valve under the sink during the fill cycle.
Good luck.
kevamhenry
#4 Posted : Tuesday, April 13, 2010 5:10:45 PM(UTC)
kevamhenry
Hi sueandrob
Good luck.
I have a similar bosch with model number shx46bo7. This past week came in from outside to find dishwasher making loud noise from the underneath. When I turned off the water shut off valve the noise quit. Have tried running a few loads since. The machine starts and seems to run fine. It intermitantly makes this grinding/fluttering noise. If I slowly turn the water shut off valve off slowly the noise quits. I am able to immediately slowly reopen the valve without noise returning until later in the cycle. I reapeat this step over and over. I have searched many forums and your answer is the only one close to my problem. Is this a problem with my water valve or is a part on my machine probably starting to break and needs replaced? I have fixed my kenmore washer and dryer issues so hoping I can fix this too.
#5 Posted : Wednesday, April 14, 2010 4:29:39 PM(UTC)
Touch the water shut off valve during that noise and, if it vibrates, call a plumber.
n2wind2000
#6 Posted : Saturday, April 17, 2010 7:13:09 AM(UTC)
n2wind2000
I have an identical problem with a Frigidaire. Sounds like the thing is snoring at certain intervals during the cycle. Im unable to identify which cycle, as I dont know much about dishwashers! It happens about 30 seconds into the cycle, and then intermittently. Ive removed the lower access panel, and all i can tell is its coming from the lower portion of the machine (I know, big help huh!). My best guess is it happens when the machine is emptying the water.
I think I spent $400.00 on the machine and am wondering if its even worth fixing vs. buying a new one. Its only 3 years old, but runs 1/2 dozen times a week.
#7 Posted : Saturday, April 17, 2010 3:49:01 PM(UTC)
We are willing to help you, but we need as much as possible description on the problem. So far it's very hard to say what is going on with your dishwasher.
n2wind2000
#8 Posted : Saturday, April 17, 2010 4:01:56 PM(UTC)
n2wind2000
Gene I cant even find the Model # on the machine!
#9 Posted : Saturday, April 17, 2010 5:11:38 PM(UTC)
It suppose to be on the door frame.
n2wind2000
#10 Posted : Saturday, April 17, 2010 5:28:13 PM(UTC)
n2wind2000
That was the first place I looked......nada.
Guest (5)
3 Pages123>
