carpenter
#1 Posted : Friday, February 22, 2008 5:10:31 PM(UTC)
carpenter
My dryer continues to run. The buzzer does not go off, and the dryer will run until I open the door (for hours if I let it). Any suggestions will be greatly appreciated.
Thanx:rolleyes:
roycreamer
#2 Posted : Friday, February 22, 2008 5:43:00 PM(UTC)
roycreamer
Groups: Expert
if it won't shut off on auto dry, try timed dry. if it still won't shut off, it's most likely the timer...
roy
mikedudl
#3 Posted : Tuesday, April 29, 2008 8:32:17 AM(UTC)
mikedudl
Thanx:rolleyes:
I replaced the short travel button assembly where you set the heat range and fabric types to cure the same problem on our GE profile dryer. Opening the door was the only way to stop the dryer before I replaced the button assy.
