Replacing the belt on my WW electric dryer. Was able to get the old belt out pretty easily thru the panel on the back at the motor, it was broken so it came out pretty easy.
Picking up a new belt today and have a diagram for the belt path when its completed.
Question Id appreciate some help on is what direction should I go at this thing to put on the new belt? From the front or the underside of the machine?
Im a compitent tinkerer but have never worked on a dryer before, any help would be appreciated
Take Care
