tommyt37
#1 Posted : Sunday, April 11, 2010 9:40:21 PM(UTC)
tommyt37
Hello folks! Yesterday after coming homeUserPostedImage from work I noticed the house was a bit chilly. Noticed air was being blown but it was only cold air.
The following is what I know and what I have looked at.
1) Heat is commanded vent motor fires up. After about 6 seconds vent motor shuts off and main fan blower kicks on. No flame, no ignition...
2) Error LED flashes 6 times. Supposed to mean 115VAC reveresed polarity or bad ground.
3) I checked all powerI have 120VAC.. getting to the circuit board. I have 120VAC on Primary of transformer and 27VAC on secondary being fed to CB.
4) I have no voltage ever getting sent to Gas valve or ignitor. Have clean filter shorted out safety switched one at a time same results.
This one is bugging me I am not sure what the cause would be... I am thinking it may be the Circuit board but I don't know. About ready to give in and call HVAC tech but any other advice would be welcome.
Regards,
Tom Spokane, WA
icehouse
#2 Posted : Friday, April 16, 2010 4:04:46 PM(UTC)
icehouse
tvtech
#3 Posted : Saturday, May 15, 2010 8:07:48 PM(UTC)
tvtech
6 blink codes is from the control board indicating the problem..... Computer never lie. Check your ground and polarity.
