duane
#1 Posted : Monday, April 28, 2008 6:56:49 AM(UTC)
duane
washer does not agitate all other function work
#2 Posted : Monday, April 28, 2008 1:27:23 PM(UTC)
Does the motor run in agitate mode?
#3 Posted : Monday, April 28, 2008 1:28:23 PM(UTC)
Does the motor run in agitate mode? If it does, you probably have a bad transmission.
jproth
#4 Posted : Friday, May 23, 2008 4:02:26 PM(UTC)
jproth
Washer does not AGITATE all other functions work fine.
SublimeMasterJW
#5 Posted : Friday, May 23, 2008 5:56:44 PM(UTC)
SublimeMasterJW
If this particular washer does everything but agitate I have found the problem is in the timer most likely.
Removing Maytag agitator (Washer Repair)
by Guest 3/30/2024 5:55:35 PM(UTC)
Maytag topload agitator (Washer Repair)
by Guest 1/30/2024 7:23:54 AM(UTC)
GE top load with agitator - drum is free spinning (Washer Repair)
Belarus JLS79 12/18/2023 8:21:30 AM(UTC)
Maytag Bravos Washer - Agitator spins fast/Drums spins slow (Washer Repair)
by JDugdale 8/29/2023 9:04:08 PM(UTC)
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
Beware when buying Agitator WPW1011020 (Washer Repair)
by Guest 7/18/2023 3:49:04 PM(UTC)
Should basket spin with lower agitator? (Washer Repair)
by bdollar 6/2/2023 4:44:56 PM(UTC)
Frigidaire Gallery Model GLWS1349AS0 Agitator Will Not Come Out (Washer Repair)
by Techowl 1/23/2023 10:39:56 AM(UTC)
My agitator bolt will not come out (Washer Repair)
by Guest 8/14/2022 4:47:19 PM(UTC)
GE Hydro Wave Quiet Agitator Wash System Lint Screen? (Washer Repair)
by Alphonse 3/13/2022 1:50:28 PM(UTC)
Whirlpool agitator&spin issues (Washer Repair)
by Guest 1/16/2022 10:55:31 AM(UTC)
Agitator barely moves (Washer Repair)
by Xicano69 10/25/2021 7:16:40 PM(UTC)
Grinding with working agitator. (Washer Repair)
by Guest 9/23/2021 1:10:18 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
Agitator Stuck! Can't get it out. (Washer Repair)
by TWash2 6/16/2021 3:22:28 PM(UTC)
