wow
#1 Posted : Monday, April 28, 2008 9:43:10 AM(UTC)
wow
Dishwasher quit draining so I replaced the drain solenoid. After about 5 days, the replacement solenoid burned out too. Any ideas as to what would case the solenoid to fail??
misterfixall
#2 Posted : Monday, April 28, 2008 12:23:19 PM(UTC)
misterfixall
how do you know solonoid is problem .what are you observing
wow
#3 Posted : Monday, April 28, 2008 12:55:55 PM(UTC)
wow
I know the solenoid fails because there is no continuity thru the coil when tested with my multi-tester
#4 Posted : Monday, April 28, 2008 1:23:23 PM(UTC)
These solenoids can fail due to power surges, or the timer sticking in drain. These solenoids will burn up( usually with burnt/melted plastic covering) if the timer sticks. Just observe the timer to see if it sticks.
