My dishwasher wont drain. Checked all hoses no clogs. Took pump off and saw no visual damage. I replaced it and felt little pressure coming out where it plugs into the drain tub. My float is broke could this have any effect on this problem. Thanks
I am having the same issue, I think. every thing seams to work but it won't drain. I don't hear the motor turn on when it should be draining. I have cleaned out the drain with a shop vac and it shouldn't be blocked.:confused:
