John Horn
#1 Posted : Thursday, April 8, 2010 9:58:45 AM(UTC)
John Horn
Dishwasher is leaking at bottom of R hand door; R hand SOUND seal on tub is missing. Could this be contributing/causing leak? Top and L hand SOUND seals are intact. Are they interchangeable?
magician59
#2 Posted : Thursday, April 8, 2010 11:20:06 AM(UTC)
magician59
If you're referring to the trim pieces that are screwed to the cabinet, surrounding the dishwasher, they are handed. I believe you can buy replacements in a kit, that then have to be cut to length. As for your leak, look at the door seal. If it's dirty, clean it with soapy warer, or a mild vinnegar solution. If it's really crusted, you might consider replacing it.
John Horn
#3 Posted : Thursday, April 8, 2010 11:58:05 AM(UTC)
John Horn
Thanks! In researching parts for this particular model, part is listed as "sound seal", is approx 23"L x 1/2"W, flexible, notched on back side, has lip that simply slips over edge of tub, with separate seal for left, right, and top of tub...is not screwed in place. Doesn't appear that later models of Maytags have this "sound seal". What do you think?
magician59
#4 Posted : Thursday, April 8, 2010 1:31:46 PM(UTC)
magician59
Here's a parts breakdown. The sound seal (37 in the diagram) is an external sound barrier. It has no effect on the water tightness of the machine. The door seal (#1 in the drawing) is the important part. It fits in the groove tha goes around the tub and up against the door to keep water in.
Tub replacement parts for MAYTAG MDB6000AWW Dishwasher - Undercounter | AppliancePartsPros.com
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
