I have a fridge on top/freezer on the bottom style fridge. The light stays on in the fridge. Where is the switch located?
Cannot say without a model number.
Often they are on the frame where the door closes or just inside on the side of the liner. Also they are often on the control console. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the reply. My fridge is the model # TCX18.
Your model number seems to be short a number of digits.
Just go to the AppliancePartsPros parts site and search for your unit. The couple of units I looked at showed a switch as item 26 in the Cabinet Parts section. Looks like it is in the console at the top of the fresh food section but I could not say for sure. |
The owners manual shows two model numbers TCX18 and TCC18. I suspect the remaining digits in that site are for options. I did see that switch #26. I couldn't get much out of that picture though. I put a magnet around the frame, but I don't know if that would trigger it. Any other sugestions?
Still a dark fridge. I can't turn the bulbs in because they wont shut off. Any one got some advice.
