jhkkknn
#1 Posted : Saturday, April 26, 2008 2:25:28 PM(UTC)
jhkkknn
My DH had the bright idea to stack our washer and dryer and now it won't heat? It worked fine bfore, it turns on and acts like it is running, so I don't think it can be a power problem? But would somthing just go that quick? It worked yesterday...
He did change the plug on the back but would that cause it to run/work but not heat???
Any suggestions
ApplianceJunk
#2 Posted : Saturday, April 26, 2008 4:59:28 PM(UTC)
ApplianceJunk
Yes, it could. The dryer has 240 volts going to it at the outlet.
The motor only uses half that, 120 volts to run, but the heater needs the full 240 volts to heat.
jhkkknn
#3 Posted : Sunday, April 27, 2008 5:37:25 AM(UTC)
jhkkknn
NOpe we changed it back and still no heat :(
ApplianceJunk
#4 Posted : Sunday, April 27, 2008 5:47:30 AM(UTC)
ApplianceJunk
Please check your model number. I can not find any info on the one you listed, but if this dryer has electronic controls or control board there is a chance the electronics have been damaged if you did not connect the cord right in the first place.
jhkkknn
#5 Posted : Sunday, April 27, 2008 6:40:00 AM(UTC)
jhkkknn
WED8300SW Whirlpool Duet
It is under warranty, I am going to call there on Monday. They are closed on weekends :(
ApplianceJunk
#6 Posted : Sunday, April 27, 2008 6:50:15 AM(UTC)
ApplianceJunk
Good idea, please keep us updated on what they find.
jhkkknn
#7 Posted : Sunday, April 27, 2008 7:04:45 AM(UTC)
jhkkknn
I just wanted to outrule anything else first :)
