Hi, Freezer seems to blow some cold air but cold enough. The right side is not blowing any air at all and its not cold. I saw some ice build up at the bottom side of the freezer side back wall. Appreciate any help.
Groups: Expert
you have an air flow issue, most likely with the defrost system, check your heater, bi metal thermostat or your defrost control.
