The water dispenser works but water doesn't get to the ice maker. I emptied out the freezer and and defrosted the freezer. I am curious if there is any other part that could go wrong besides the Dual Water Inlet Valve. The refridgerator does not have a water filter.
Thanks,
Brian
Groups: Expert
Well, i dont mean to point out the obvious, but you could also have a problem with your ice maker
Originally Posted by: brinan  The water dispenser works but water doesn't get to the ice maker. I emptied out the freezer and and defrosted the freezer. I am curious if there is any other part that could go wrong besides the Dual Water Inlet Valve. The refridgerator does not have a water filter.
Thanks,
Brian The ice maker auger still turns when pushing the ice dispenser lever. Do you have an idea which part I need to order. Thank you, Brian
Groups: Expert
