madailey
#1 Posted : Friday, April 2, 2010 4:05:10 PM(UTC)
madailey
I ordered a new door frame for my microwave. I need removal and installation instructions.
madailey
#2 Posted : Friday, April 2, 2010 4:15:08 PM(UTC)
madailey
I need do it yourself instructions
on replacing my door frame.
Migeguy
#3 Posted : Friday, April 2, 2010 8:06:50 PM(UTC)
Migeguy
Remove grille,2 screws on top of cabinet hold it on. Open door the 90 deg and lift off hinges. Lay door flat and remove choke cover,a small putty-knife works well to lightly pry the cover up.It has friction tabs holding it in place. you can now access the screws to the frame and will also need to carefully pry open tabs holding the frame to the choke.
