mhamil1017
#1 Posted : Thursday, April 1, 2010 10:07:51 AM(UTC)
mhamil1017
How do I adjust the oven door hinges? I was changing the convection fan, overbalanced, and leaned heavily on the door. Now the door gaps at the top.
#2 Posted : Thursday, April 1, 2010 2:29:17 PM(UTC)
Make sure the inner door liner, oven door frame and door hinges are not bend. The door hinges are not adjustable.
mhamil1017
#3 Posted : Friday, April 2, 2010 7:56:50 AM(UTC)
mhamil1017
Gene,
Thanks for the input. FYI, I found a rotating stop on each hinge. I rotated the stops down to the hinge and closed the door. Then I applied closing pressure on the door and the hinges realigned themselves. The oven door now closes like new.
#4 Posted : Monday, April 5, 2010 8:19:01 PM(UTC)
Good to hear it. I'm glad it was that simple.
btk4962
#5 Posted : Saturday, April 28, 2012 2:32:22 PM(UTC)
btk4962
I see how he talks about fixing the issue below, and I am having the same issue.
How did he get to the hinges? and this totating stop?
Guest (4)
Samsung - Oven Door Won't Close Tight (Oven Repair (including Ranges and Cooktops))
by Samich 4/26/2020 7:59:48 AM(UTC)
Oven door won't close tightly-has a gap (Oven Repair (including Ranges and Cooktops))
by gloverzoo 3/30/2015 7:45:00 PM(UTC)
Jenn-Aire Oven door won't Close (Oven Repair (including Ranges and Cooktops))
by jgmann 10/28/2014 11:58:22 AM(UTC)
GE Profile Oven Door won't close (Oven Repair (including Ranges and Cooktops))
by TeriT 8/27/2014 10:13:22 AM(UTC)
Thermador oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by fixitboy 11/26/2013 12:22:35 PM(UTC)
Kenmore Oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by ritarandall 9/24/2012 4:00:48 PM(UTC)
Oven door won't close (Oven Repair (including Ranges and Cooktops))
by DottieH 5/29/2012 1:15:24 PM(UTC)
Oven door won't close all the way... (Oven Repair (including Ranges and Cooktops))
by RN2010 11/21/2010 1:48:57 PM(UTC)
Oven door won't close right (Oven Repair (including Ranges and Cooktops))
by tsimonsen 5/28/2010 4:23:12 PM(UTC)
Oven Door Won't Close!!! (Oven Repair (including Ranges and Cooktops))
by glenardee 9/28/2009 3:53:40 PM(UTC)
oven door won't close (Oven Repair (including Ranges and Cooktops))
by jeanpier 7/25/2008 11:22:47 AM(UTC)
by hamconsulting 7/21/2008 8:37:21 PM(UTC)
Viking oven door won't close (Oven Repair (including Ranges and Cooktops))
by McDoo 12/3/2007 4:37:00 PM(UTC)
