When it's pluged in moter runs but it won't get cool.
Originally Posted by: Walleye cooter  When it's pluged in moter runs but it won't get cool. I have the same fridge in the garage for a wine cooler. When I first bought it I thought it was broke but I turned the dial(in the back by the condenser) all the way up and now it works ok. Not COLD, but everything is COOL. I've heard HAIER is no good. By the way, the freezer in it will never work.... get used to it. It just freezes when its running and then melts water all over off the freezer.
Originally Posted by: ChrisMNS.Ut  I have the same fridge in the garage for a wine cooler. When I first bought it I thought it was broke but I turned the dial(in the back by the condenser) all the way up and now it works ok. Not COLD, but everything is COOL. I've heard HAIER is no good.
By the way, the freezer in it will never work.... get used to it. It just freezes when its running and then melts water all over off the freezer. You may have a door seal problem or thermostat . As regards to refrigerator working continously coukd be out of FREON ,arestriction or compressor not pumping:cool:
Haier Wine Refergerator Does Not Cool
