blofgren
#1 Posted : Sunday, April 20, 2008 1:42:04 PM(UTC)
blofgren
My dryer is pumping air and heat into the clothes, but the cylinder is not rotating. I first opened the panel on the back, which gives access to the air in and out. Apparently I must open the front, but I'm not finding how. I'm also putting in a request directly to Whirlpool for the manual, but they are closed today. I guess I might need to replace a belt or maybe a motor.
Brent
gearhead1218
#2 Posted : Sunday, April 20, 2008 5:15:17 PM(UTC)
gearhead1218
You need a belt.
If you click on your model# on your initial post you'll see a breakdown of your dryer.
You do need to remove the front.
You pull the lint filter, remove the two screws on the filter compartment, Then you can slide the top forward about a 1/4 inch to be able to lift the top. Undo the door switch, remove two 5/16 screws and you can remove the front to change the belt.
blofgren
#3 Posted : Monday, April 21, 2008 5:59:24 AM(UTC)
blofgren
Thanks, Gearhead. This site rocks, and I've ordered the belt from you. Mainly, it was smarter than the Whirlpool site at picking up that the last character in my model number is the number zero, rather than the letter O. I don't have immediate access to the dryer itself, but I hope that I will be able to open it up and replace the belt according to your instructions.
Brent
gearhead1218
#4 Posted : Monday, April 21, 2008 11:48:16 AM(UTC)
gearhead1218
Glad I could help.
As an aside, I'm just a member here, not one of the people running the site.
blofgren
#5 Posted : Wednesday, April 23, 2008 4:19:30 PM(UTC)
blofgren
The idler pulley is supported on both sides, so it is a closed loop. The new belt is a closed loop, too. (As surmised, the old belt was completely broken.) How do I thread the belt through the idler? It seems like those rings that magicians use.
gearhead1218
#6 Posted : Wednesday, April 23, 2008 4:47:57 PM(UTC)
gearhead1218
UserPostedImage
alexis123
#7 Posted : Wednesday, September 24, 2008 2:51:52 PM(UTC)
alexis123
head1218;20263]UserPostedImage
I did this alreeady do I need to tension the belt
libertyappl
#8 Posted : Wednesday, September 24, 2008 2:59:30 PM(UTC)
libertyappl
If The Belt Isn't Tight The Idler Pulley Arm May Be In The Wrong Slot.
Nat
Guest (4)
Dryer Heating But Not Tumbling, Heating with Door Open (Dryer Repair)
by RadMax8 7/4/2015 8:35:36 PM(UTC)
GE Dryer NOT TUMBLING (Dryer Repair)
by dscott31508 4/30/2015 9:52:17 AM(UTC)
GE profile harmony dryer not tumbling (Dryer Repair)
by Torey 9/30/2013 8:34:05 AM(UTC)
by @shley1! 5/3/2013 7:36:48 AM(UTC)
Whirlpool Dryer Not Tumbling (Dryer Repair)
by Phiphtie 5/14/2012 7:01:29 PM(UTC)
Maytag Dryer Not Tumbling (Dryer Repair)
by timros 1/16/2012 2:06:15 PM(UTC)
Kenmore 90 Series Dryer not tumbling (Dryer Repair)
by rmlahaie 2/21/2009 10:01:24 AM(UTC)
by SROBERT56 9/23/2008 1:14:45 PM(UTC)
