I am desperatly trying to fix my dryer that went flop today. Tub runs, Heating element replaced. Had fuses (2) checked and they were not damaged. Cord connection tightened, Breaker turned off and held then turned on. We are in nned of someone who might have any ideas and someone who can show me a diagram of the wiring and where the duct fuse is. Also how to take the motor switch out to clean it? any idea or help would be so greatly appreciated as I don't have a income and I am disabled and can afford a new one for sure, can't afford a service call, can't afford a used one. HELPPPPPPPPPPP Donna
Hi, Pop the top of the dryer and check the black round thermo fuse that mounts on the inside of the back wall. It will be near were the corder enters the dryer. In this photo you can see the two thermostats. It's the smaller one that is on the back wall that you will want to check first. Thermo fuse photo
