pgmr
#1 Posted : 18 years ago
pgmr
This oven has started losing it's display (the fluorescent one, not the LED). It will come on after a long power cycle, but will go off after a few minutes to a few hours. The halogen and microwave functions still work when the display is blank.
There are two boards that I've seen that could be causing the problem:
WB27X10358 - Smart board
WB27X10336 - Fluorescent Display board
I've not been able to find any schematic showing the pinouts of the connectors going from the Smart board to the Fluorescent board, therefore I cannot determine if it is a power supply problem or a display problem.
Thanks.
Admin / APP Team
#2 Posted : 18 years ago
Admin / APP Team
Rank: Administration
It's almost impossible to find schematics for GE appliances. There should be a schematic inside the unit though. Usually inside the control panel or taped to the inner side of the outer case.
pgmr
#3 Posted : 18 years ago
pgmr
I had discovered the schematic inside the unit, but it didn't even show the connectors going from the main board to the display board.
Turns out it was the WB27X10336 - Fluorescent Display board.
Admin / APP Team
#4 Posted : 18 years ago
Admin / APP Team
I'm glad you found the problem.
