chashamly
#1 Posted : Monday, March 29, 2010 5:37:44 PM(UTC)
chashamly
The unit is about two years old and the refrigerator side gets too cold. I tried to raise the temp but it turned itself back down. it froze the water line to the water dispenser. It froze the produce in the drawers. Any ideas? Thanks!
magician59
#2 Posted : Tuesday, March 30, 2010 7:37:50 AM(UTC)
magician59
This sounds like either a bad thermistor, or the mother board is faulty. I don't know if the thermistor can be found as a separate part. Part number: AP3191003
chashamly
#3 Posted : Tuesday, March 30, 2010 9:07:12 AM(UTC)
chashamly
I would think the motor assembly is controled by the mother board and the mother board gets its signal from the thermister. If the mother board keeps turning the temp down when I turn it up wouldn't you think its the mother board? If I buy both parts I figure it will fix the issue. What do you think? Which mother board? I think the fridge has two. Thanks
magician59
#4 Posted : Tuesday, March 30, 2010 9:59:17 AM(UTC)
magician59
The problem might be solved by replacing both parts. As long as you realize that ONE of those parts is probably an unnecessary purchase, and you're OK with that...
The mother board is the one behind the panel in the back, just over the water inlet valve.
