ljbean
#1 Posted : Wednesday, April 23, 2008 8:16:37 AM(UTC)
ljbean
Replaced the Dual Gas Valve in the subject unit because the Bake Ignitor would come on, glow brightly and maybe and maybe not the Bake side of the valve would open. Broiling side works fine. Baking side of new valve will not open even though Ignitor is glowing brightly. And, again, Broiling funtion works fine. Checked voltage between Ignitor and Valve. It was around 3 vac hooked to valve and 118 vac checking with lead disconnected from valve. Can't figure this one out. Any suggestions?
misterfixall
#2 Posted : Wednesday, April 23, 2008 1:24:57 PM(UTC)
misterfixall
replace bake ignitor
ljbean
#3 Posted : Monday, April 28, 2008 12:15:20 PM(UTC)
ljbean
That Fixed it! Thank You Very Much! :D
